Hello
Hoping you can help me understand that I am understanding this properly:
Our system is a boiler in the kitchen (Potterton Promax HE) and a tank in cupboard on the first floor, timer controls are also there for hot water and central heating - we had an issue earlier in the year with a two port motorised valve (acl Lifestyle) in the tank cupboard: the one controlling hot water wouldn`t close - so a plumber, as a quick solution, wired the hot water over to the central heating valve, as a result both would turn off and on simultaneously, all controlled by our heater thermostat. While this might not suit most people it works fine for us as the tank hot water is only used for the kitchen taps (our shower is electric).
Obviously the slight issue is in summer when the heaters are not needed at all - so my bright money-saver idea was that during the few months of summer, if we turn off each radiator valve we could run the boiler and still have hot water without a hot house. I ran this by the plumber at the time and he seemed to say it would work.
Now in Summer I have put the plan into action. It doesn`t work - reason being that the pilot light on the boiler has gone out; specifically when the thermostat is set to be on, the boiler hums softly but doesn`t fire up.
So the question is - is the boiler`s not firing up somehow connected to the fact that all the radiators are closed? Or is it just a coincidence: the boiler should work for hot water even if the radiators are turned off, but the boiler has a separate pilot light issue now?
If you could please help me understand this would be wonderful.
Many thanks
Mike
Many thanks
Mike
