Hi
My boiler is in the garage and last winter the frost stat kicked in more than I'd have liked. Now I know it's necessary, but I'd like to reduce this as much as possible.
The garage is almost triple length with open eaves, so I was wondering how aggressively I could insulate the boiler area including frost stat. Currently the boiler is unenclosed.
It seems likely to me that I should not fit a closely fitting cupbaord and pack insulation in to virtually surround the boiler.
But what size of enclosure with 100mm insulated walls can I fit around and above it? How much free space does there need to be around the boiler, would a foot on all sides be enough? If it is room-sealed can I do this with no vents?
My other concern is the (Hep20) pipework leading to the boiler across the garage. Currently the frost stat kicks in a lot and so the pipework is kept fluid by the boiler starting up. If the boiler+stat cabinet / room is insulated then it will fire up as much as is required to keep the boiler unfrozen, but could I then suffer side effects such as the condensate or flow pipework freezing....?
