Boiler in garage
8 Aug 2010
Hello, newbie here and clueless I'm afraid.
We are looking at getting a new central heating system put in, and the plumber has suggested the best place for the new boiler is in the garage, on an outside wall.
I'm not convinced (but hey what do I know)! I'm concerned about freezing pipes if we have a snowy winter again, and with the frost protection that the boiler will be turning on a lot of the winter overnight.
What are your opinions on boilers in garages, any advantages or disadvantages? Thanks.
Is the garage attached to the house?
If so it's common, though pipes are hardly ever properly insulated.
Make sure he sleeves the pipes into the house, it give them a bit more protection.
You can always build a small cupboard around the boiler, to keep it a bit warmer, and handy for storing stuff at the same time.
Frost stat with pipe stat, if it "does" come on, it wont be on for long, also if it's a combi with a DHW preheat, the boiler will stay warm anyway, garage, good place for it, out the way and easy maintenance.
Thanks everyone.
Garage is half integral, boiler would be on outside wall in non-integral bit near the door. There is an old car in the garage which does not move, so it won't be that easy when access is required.
Don't think we will go for a combi boiler, but not 100% decided.
I guess I was worried because I was looking at a plumbing forum (can't remember which it was) and the plumbers were saying most of their work last winter was caused by frozen pipes from boilers in garages!
If you go the combi road, consider how far away the draw-offs are.
If access is limited, can he install the boiler.
This will have been the condense pipes freezing up, not as serious as a burst mains or heating pipe. Just makes sure it's ran in 32mm and is lagged. You can even get thermostatic heating elements to wrap around them now.
Definately use Fernox Alphi Inhibitor with Antifreeze in the Primary Circuit,
Last winter we were treading around in a Foot of Snow in East Anglia, did lots of Boiler Breakdowns on outdoor and Garage located Boilers but NOT ONE FROZEN PIPE!! ;)
