I have a house to be completely refurbished. It is a bungalow with a loft space.
I have heard it mentioned that a boiler can be placed in a loft.
I have a reasonably sized loft with a reasonably large flat (gable end) wall at the back. I am planning an LPG boiler. AIUI all modern boilers are balanced flue nowadays.
So is that right? Or is there a problem putting a boiler in a loft?
I was also wondering about plumbing it.
It seems the ordinary heating/HW circuit would go:
Boiler (ground floor), 22mm pipe to
T off to vent pipe (22mm) (not sure where this would T off), short 22mm pipe to
T off to pipe to header tank (in loft) (15mm), 22mm pipe to
Pump, 22mm pipe to
3-way valve,
22mm pipe to HW tank,
22mm pipe to radiators (in parallel)
then the HW tank and radiator system returns in 22mm to the boiler
In my system though, the header tank would only be slightly above the top of the boiler. The HW tank would be on the ground floor. I thought the pump would go next to the HW tank, so on the ground floor.
Would the ordinary layout work on my system, or would I get difficulties?
Is there an alternative layout which might work better? Or should I be better off getting in an expert?
Pump, 22mm pipe to
3-way valve,
