I want to fit isolation valves in the boiler feed and return. This would be useful if the boiler need to be replaced, the same as with a pump. However it would be before the vent so would this be ok? Obviously closing the valves and firing the boiler would be a BAD idea and there should be a pressure relief valve before the isolation valves in case of idiots or valve faults.
What valves are best, gates, or balls?
BTW mostly this is because I want to get on with replacing my coal fired system before I have to fit a condensing boiler which are not available in wall mount and have other problems with where I want to site it. I need valves so I can run the coal fire to burn the 2 tonne of coal I have, then swap to the oil. Otherwise I'm changing the heating system in winter .
