I had my boiler, Ideal Classic RS 240, serviced and the engineer that serviced it advised to have it switched off as he didn't think it was properly room sealed. He tried to ring Ideal to confirm this but as it was a Saturday afternoon there was no one there. He has said to get someone out to reseal it but ideally I want to confirm the situation rather than paying a call out charge only to find out that it is supposed to be like it is.
There is a rubber seal around the edge of the boiler case where it meets the wall mounted part of the unit but there is only a seal around the top and two sides, there is no seal across the bottom of the case. The engineer said that he has seen some room sealed units with a small gap but never the whole width of the boiler.
I am going to try calling Ideal myself but I don't know if they will give me this information as obviously I'm not qualified to remove the cover of the boiler so just wondered if there was anyone that can shed any light on this.
Just to fill in a bit more of the background to this, when the engineer removed the front cover of the boiler it wasn't screwed on properly so it appears it has been tampered with by a previous occupant of the house, especially as the cover has been painted and would have to have been removed to do this. This was the first time I have had it serviced since buying the house.
Hopefully the above makes sense and someone can be of assistance.
Thanks in advance
Thanks in advance
