Boiler: Glowworm fuelsaver F45
Symptom: Once up to heat, boiler runs for 30sec -minute then turns off as is overheating.
Actions: 1 Have drained the system several times and each time added stronger cleaner, Fernox, sentinal , Wickes own, the final was Fernox Ds40 - citric acid. No improvement.
2 Have just spent several hundred pounds having the system powerflushed with water and magnet cleaner. The engineering added Fernox f2 the week before to pre-treat - when compared to the videos on line not much really came out - the magnets were ringed rather than fully coated. So happy system is as clean as it can be. Also changed the 3 way valve and added a Fernox omega filter.
However, the problem persists. The engineer now says it is the heat exchanger but he will not investigate it further and is recommending a new boiler.
I live near the South Downs in Hampshire so water is very hard, so probably the heat exchanger is full of calcium deposits?
The boiler is 30 years old (has not been run hard - I am comfortable at 16'-18') and the part is obsolete so replacing it is probably not an option. So can it be cleaned - whilst in situ or remove it and clean with descaling acid outside? Are there any filters which may be blocked?
Can anyone suggest another solution or better still is there any one in south Hampshire, woth experience of this who can come and provide a solution.
Here's hoping!
Here's hoping!
