- Joined
- 16 Mar 2006
- Messages
- 20
- Reaction score
- 0
- Country
History.
The boiler is about 20 years old and was fitted new when we bought the house, I believe it's an Ideal Elan II.
A couple of years ago I was advised to use some descaler to clean the system as we had bad boiler kettling, prior to this I had renewed the pump after being told that that could have caused the problem, unfortunately it wasn't that. The descaler seemed to do the trick until just recently when the kettling/banging started again. Although the pump did appear to be stuck at one point, I freed it and it ran ok afterwards (it still seems ok).
In the last couple of days I have used Sentinel x400 de-sludger then flushed with clean water, that didn't seem to help although lots of brown water drained out. Yesterday I drained the system again and now have Sentinel x200 de-scaler in the system, I've bled the radiators again and balanced them.
Last night after doing the above, the boiler once again started kettling/banging but when I manually turned down the stat (to 50c) on the hot water cylinder it seemed to run ok for the rest of the evening .
This morning my wife turned the heating off until I returned from work, as the boiler was kettling and banging again. I got home and turned the heating on, it ran fine for 10 - 15 mins before playing up again, I fitted a new cylinder stat as I thought that could just be the cure, it wasn't.
The system has a 3 port motorised valve, the clock/control has 2 heating options, HW or HW/CH.
I'm wondering if the 3 port valve could be at fault but I don't know how to check this, can anyone help me with some advice ?
Sorry if it's a bit long winded but I'm trying to give as much info as possible.
