I have an Ideal mexico CF 40/60 floorstanding boiler that is situated on the ground floor. There is a hot water tank on the 1st floor which is gravity fed from the boiler.
When the boiler fires up, there is a knocking noise from the boiler which echoes around the house. I'm fairly sure that the problem is kettling (also confirmed by a plumber) but no matter what I do I can't seem to cure it.
I desperately need a solution as the boiler starts up at 6:00am every morning, which wakes up my 4 year old. Anyone with kids will know that within 5 minutes the entire house is up and watching cebeebies!!!
I've tried the following:
1. drained the system and refilled adding x200 and inhibiter.
2. drained the system again and added more x200 and inhibiter
3. turned the boiler thermostat down to between 1 and 2 (54 to 60 deg C)
Would fitting a pump to the primary circuit help? this would speed up the flow through the heat exchanger and I believe in theory reduce the chance of the water boiling? If so, does anyone know what pump I should install?
Is the boiler "knackered", is it time to replace?
Any other advice??
thanks
Any other advice??
thanks
