My boiler makes a hissing sound similar to that of an electric kettle, is this what is referred to as kettling and how can this be cured/minimized.
i have a vented system with a f/e tank in the loft, i have recently replaced a zone control valve and am in the process of bleeding air out of the system - the pump gurgles and churns every now and then, and in particular when the hot water is first turned on
The HW circuit was drained then filled after replacing the valve, no chemicals were replaced - should there be a fernox protector in there? would a lack of this chemical be related to the kettling/boiling noise due to there just being plain water boiling in there as opposed to a chemical mix with a much higher boiling point? The whole thing started after refilling the system.
Am in the process of investigating the possibility of air leaking into the system via expansion pipe, but i am unsure of the cause of the kettling/boiling sounds
Any help would be mostly welcome - thanks
