Boiler Loosing Pressure
18 Nov 2005
Hi - I have a Myson Midas Si which is about 20 years old and it has started loosing pressure. I find that I have to top it up with water every day to keep the minimum operating pressure of 1 bar.
I have checked rads for leaks and all seem fine and there is no sign of leaking around the boiler so I am wondering why the pressure is dropping?
Could the main heat exchanger leak when it gets hot maybe and turn the water to steam?
Thanks in advance,
Chris
Wacky idea that. I have just read some similar posts and checked the overflow from the safety valve on the boiler to the outside which is dripping.
Is a new safety valve likely to solve the problem?
Thanks again
Chris
