The problem I am having is two fold. My boiler (Worcester 28i)has been losing pressure gradually so I tried to top it up. It went up slowly and when I turned it off it gradually went straight down again. I found the reason for this as it had caused quite a heavy leak in the towel rail in the bathroom. Once the pressure dropped the leak stopped.
Do you think a bleed of the towel rail should help or does it sound like a bigger problem than this?
I have had the central heating on since and all other radiators heated up OK but the towel rail remained cold (well lukewarm at the very bottom).
