Boiler making a fast ticking sound?
15 Nov 2017
Hello all
My Boiler is making a very fast , very very quiet ticking noise, you have to go right up to boiler to even hear it, about 3 ticks per second.
It does it even when heating and hot water is not running also.
Its a Vokera Riello.
Is it something to worry about? what should be done if anything?
Thanks hoping thats all it is. If it is kettling, then will it go away on its own?
We had a similar thing years ago when we kept hearing an electronic beeping noise coming from the loft at random times. Turned out to be our holiday alarm clock in one of the suitcases and the low battery warning was going off.
That’s just reminded me of another noise I had to sort out on a car. The customer described it as sounding like a loose wheel nut rattling underneath the hub cap. Turned out to be...a loose wheel nut rattling underneath the hub cap!
I once worked in a house that the couple had renovated, thay had strapped out and sheeted the walls,a few months later they had boxed in a smoke alarm and the battery had got low and was beeping, they didnt want to rip the plasterboard to try and find it, so they were just hoping the battery would eventually give up completely, that would have driven me mad
Haha well it was a big relief to discover that was what it was. But by pure coincidence today I actually heard the exact same sound as the malfunctioning alarm clock and it was coming from the shower. I can not figure out exactly where but coming from around the shower. Also noticed last few days the shower makes a screeching sound when I turn the tap on at a certain point? but it only makes the high pitched screeching nose when shower is running and not when in bath mode. Maybe shower spout or tub faucet?
Any thoughts? Hoping its expansion noise,
Although if it is kettling, then will it go away on its own? or how can I get rid of it?
