- Joined
- 25 Jan 2010
- Messages
- 32
- Reaction score
- 0
- Country
Hi everyone,
I recently drained and refilled my sealed, combi-boiler system. I bled the radiators but did nothing to the boiler. It has an automatic air vent, which I think is open (it is a little raised, seems to possibly bubble a bit).
This morning, the boiler started making some unpleasant noises (my wife described it as like an aeroplane flying overhead). The noises came and went at regular intervals and appeared to be getting louder each time. Each time the noise occurred, it was preceded by a hissing noise which increased in intensity, followed by a loud hum which peaked and disappeared.
So... I'm debating whether I have some air in my boiler pump. Or perhaps I just have crud in my system, perhaps loosened by my recent draining. I plan to flush the system this evening, followed by adding Sentinel X400 and running for a few days. Then I plan to flush down and add some Sentinel X100 inhibitor before leaving it for good.
So, my question is basically this: do my current symptoms sound like air in the boiler? Or something else? If it sounds like air, should I perhaps manually bleed the pump (i.e. turning the big screw)?
Would it be just as wise to ignore the current noises, flush the system and proceed with my de-gunging efforts?
Note: I've not been running the boiler all day, just in case the noises were the sound of my boiler ripping itself apart!
Thanks in advance,
Duncan
Thanks in advance,
Duncan
