Weird one this. I had noticed that the heating system was making a lot of noise this morning ( gurgling ) so I tried to bleed the radiators. Nothing appeared to happen so I thought I had better check the expansion tank. The system just heats radiators and does not supply hot water.
The tank was empty and the ball-valve was stuck up. I released the valve, allowed the tank to fill then began to bleed all the radiators. After doing this, I checked that the tank was still full - it was & turned the heating back on.
After 5 mins, there still didn't seem to be any hot flow through the main 22mm pipes downstairs, so I went upstairs to see if anything was wrong. I was greeted by a dull red glow coming through he pilot light viewing hole and a nasty niff !!!!
I turned the boiler off instantly as you can imagine. I'm guessing that after bleeding the rads, an air-lock or summat had managed to find it's way into the boiler ? Is there a procedure to bleed the boiler/pump area ?
I can't afford to get anyone in atm coz I'm skint and the bloody weather means we need the heating on really, if only to prevent any freezing problems.
Any help would be gratefully received guys.
