boiler noise when CH fires up
6 Jan 2007
My ariston eurocombi boiler has started to make a whining noise for about 10 minutes each time the CH fires up. Once it has been on for 10 mins or so, the noise stops, but it is still a little disturbing. Any ideas for an easy fix, or is this another expensive call out? Many many thanks
If someone needs to go into comb box you will probably need a new front panel as the buggars are stuck solid
possibly a scaled up heat exchanger
i assume boiler has been annually serviced?
you can add chemicals to the system water to quieten down old systems but its only a cover up
