Boiler noise
7 Aug 2004
My wall mounted Boiler in the kitchen has this sound like falling water coming out of the pipework above it. I presume there is air going thru it somehow. Very noisy when boiler stops burning.
Any ideas or cures
It's air, but first look at the third post at the top of the forum and answer the questions.
Righty ho!
I have a Potterton Nettaheat Electronic Gas boiler on the Utility room wall. boiler is 12 years old. Two pipe come from top of boiler into ceiling above
I have just knocked the kitchen joining wall out into the utility room so the noise is noticeable
The noise is only noticeable when the boiler stops burning and sounds like water falling. Been doing it over a year.
The household water gets nice and hot and I have noticed the radiators get warm/hot now even with the heating off.
Sounds like your boiler stat maybe not working properly and allowing boiler to get too hot and when the pump turns off there is too much heat left in the boiler causing noise as it trys to get away.
If the flow of water through the boiler is insufficient, then the boiler can be noisy. It is very important to have the correct water flow rate, especially in wall-hung boilers. Steam bubbles can cause hot spots in the boiler, which can produce loud bangs. The cause is usually due to corrosion and scale forming in the boiler. Add non-acidic cleanser plus a de-scaler .to the feed and expansion tank.
