E
eddy42
I have a problem with an Ideal Standard cast iron boiler 50,000 btu, I am getting a slight noise from the inside of it. System is 7 years old, Flowmax hot water store, 2 pumps and mains pressure hot water. Recently I drained the system and changed a radiator to a small towel rail "Mere" supply pipes changed to 15mm from 10mm, have turned the rad inlet down to almost off. After filling the system and adding 2 lt of Sentinel also bleeding the rads I am getting a slight noise from the boiler from a distance its like someone bouncing a ball against a wall every now and then, putting my ear to the boiler its from inside the boiler not the hot water tank. The boiler is in a utility room wall mounted, feed pipe go up into the ceiling and across into the garage and into the airing cupboard, pump are set on high or '3' the hot water store is 120 lt tank no water or pipes in loft
I have two raised pipes with screw caps on them by the hot water tank have opened these to let the air out. How can I tell which is the first and last radiator in the system.
Also on the cold water supply to the tank there is a small blue tank with a screwable cap on it, i say keep to 2 bar pressure. I've never filled this with air in 7 years what is this for and what does it do? we live in fairy hard water area
Many thanks
Many thanks
