Hi
I am having issues with getting my ancient (Gloworm Fuelsaver F) conventional boiler to fire up for central heating. When the room stat - (a Theben Ramses 811 top1) has been turned up and heard the audible 'click' the boiler does nothing. DHW is running fine and the tank thermostat fires the boiler fine.
I initially thought I had a faulty programmer (an original Drayton Switchmaster 805) which I have now replaced with a Drayton LP241. The programmer seems to work fine, I can turn HW heating on/off via the programmer fine.
The room stat has a 2-wires connected so I'm hoping to find a cheap compatible replacement.
The manual for the current room stat is
http://www.theben.de/var/theben/sto...instructions_RAMSES811top_RAMSES812top_en.PDF
Any help would be very much appreciated. Is it possible to override the room stat and force CH 'on'?
Cheers
Cheers
