Boiler: Stelrad WRS 450
Room Thermostat: Honeywell
Control Unit: Honeywell ST6400C
3-Port Valve: Myson MPE322
Hi guys,
The hot water appears to be working ok. However, when the heating is meant to be on, the boiler does not fire.
I investigated the 3-port valve in the loft - when I moved the slider to heating manually, the boiler fired up and (thankfully) the place warmed up. So is the problem therefore with the 3-port valve or have I missed something? Should the slider move itself under normal operation?
The heating has stayed on for a few hours and is still working - will the slider move back of it's own accord and will the problem reoccur when that happens?
Are there any other checks I need to do? Is it something I can fix myself?
Thanks for any help!
Tris.
Hi guys,
Tris.
