Hi all
I've a Ravenheat HE85T combi which recently has had new (dry type) CH sensor, diverter valve and microswitches (twice now).
I noticed a fault of intermittently boiler not firing for DHW when cold (when CH is in OFF mode). The boiler fails to sense the demand for DHW and therefore does not fire. I can hear the cold water running through the boiler (like a hissss sound) but the boiler does not fire up at all.
I replaced the microswitch with a new one but the fault is still there. Its very intermittent and generally comes when the boiler is ice cold...
I've also checked that the pin from diverter valve is coming out and pressing the buttons on the microswitch. More than 50% of times it fires (when CH is OFF).. There are 2 pink wires going from microswitch into the front instrument panel. Do I need to open that and look for a loose connection type of fault or could it be the PCB?
The CH is working fine and the DHW works just fine when the CH is ON!
Any ideas where to look?
Thanks in advance...
