good point! have been using fluke multimeter to check circuits, a/p switch has contacts 1(normally closed) 2(n/o) and3(c) if I test between 3 and 1 and 3-2 that would tell me if the switch was ok
Not sure what connection is what in your case, but in general it is quite simple.
Test 2 contacts on continuity, if no sound, blow on pipe and hear beep. Change one of the contacts and hear beep, blow on pipe and silence. The remaining 2 won't beep no matter what you do.ote]
Hi and thanks, there is a red and clear plastic pipe.I removed the clear and tested as instructed.(I removed the pin plug from the pcb) there was a continuous beep which blowing down the pipe did not clear??
hope you bear with me on this.
