Boiler Not Firing Up
28 Nov 2005
Worcestershire
Sorry another one of those \\\'Boiler Not Firing Up\\\' posts.
I came home from work tonight and the warmest place in my house is my fridge!
My boiler in the garage looks quite old (in when we moved in a couple of years ago). It says on the outside ‘Ideal Standard’ I cant find a model or anything and the pilot light is on.
This boiler supplies pumped water to the rads and also heats the water in the cylinder.
I recently replaced my room thermostat, water pump, cylinder thermostat, timer and everything simply plugged into a circuit box.
The system worked fine until today/tonight. The wall thermostat ‘clicks’ (at 10 degrees!) but the boiler just flickers and fails to fire. I can hear the pump pumping away pushing cold water around the system.
Brrrrr :rolleyes:
have you checked the motorised valve is working ok? it sound more like a control fault than the boiler. you could put a temp electrical supply to the boiler to see if it fires.
oooops....its gas!!!!
(post edited.. situation )
i thank you.....
