Camray 5 oil fired boiler. I bled a radiator in the bathroom this morning & now my boiler will not fire up. No red lights showing only green ones. Any ideas?
Have you checked the lead to the burner is plugged in? (open the front of boiler and follow lead up from burner), also check high limit reset while you're there.
Can you here water pump starting when you try to get boiler going?
