I have an old gas boiler with a gravity fed hot water system.
It does not appear to be heating the water in the cylinder at all!
There is a tapstat on the pipe between boiler & cylinder, similar to this: http://www.heatingcontrolsonline.co...html/acl-drayton-28mm-2way-tapstat-p-190.html
I have noticed that there is a temperature differential across the tapstat - the boiler side is hot, whilst the cylinder side is cold.
I have unscrewed the head, which I think *should* open the valve, and can operate the pin on the valve with my finger quite easily.
Is it possible or likely that the valve is stuck in the closed position, and if so is there any way to free it off without draining the system down and dissembling it?
If the valve is faulty, is it worth replacing it? I suppose it improves efficiency if the boiler is running for central heating and the hot water cylinder is already up to temperature, but does it make that much of a difference?
