Boiler not heating water
29 Dec 2006
Hampshire
Hi there!
Background: Drained central heating system ( with header tank) to resite radiators. Filled up system, opened stopcocks and bled radiators.
Unfortunately, there is no hot water. Boiler is firing up. Should I have done anything more when refilling system? Pump seems noisy......airlock somewhere else?
Would appreciate some advice. Cheers.
Check if there is a bleed cap on flow pipe to cylinder if so loosen it until water appears
Also if it is a fully pumped system, did you open the zone valves manually whilst filling the system?
