I have the following problem:
Heating switched off
Hot water switched off
Hall thermostat set to 15degrees
Frost stat in garage set to 4degrees
pipe stat set to 10degrees
I have a Potterton Suprima 100L fitted in the garage and a Honewell L641B1004 pipe stat and a Potterton frost stat.
Problem:
Every 1 or two minutes boiler switches on and the radiator in the hall is boiling hot.
Why is the boiler always on although the heating and warm water is switched off?
Btw, temperature in garage is 9degrees so frost stat should not kick in.
Any advice is really appreciated.
Ulrich
Problem:
Ulrich
