I have a problem with my boiler, and im not sure where to start.
I had a problem a month or so ago, and managed to fix it by replacing the programmer, but now i have a new problem.
The problem seems to be, that the boiler doesnt fire up when it should do. If I run the system on constant, it will fire up for 5 mins then shut itself off. I think its something to do with the water temperature, because if I turn the temp of the boiler up to max, it fires up.
The pump seems to be whirring away fine, it gets hot to touch, but dont think thats the prob.
Where should I start?
Its a potterton Flamingo boiler, with a honeywell timer, motorised control valve... if theres anything else i should list let me know.
