Hi all, I'm new here but trying to solve an issue with our Ravenheat boiler. It's an RSF 820/20 boiler.
The pilot light is on but we've had an issue where the boiler takes a while to fire up when you put the heating on or run the hot tap. This has gradually become worse recently and sometimes it can take up to 5 minutes for the burners to fire up.
Originally we contacted Ravenheat and were told it was symptomatic of the air pressure switch malfunctioning.
We removed the switch and gave it a good clean and re-fit it. Upon doing this we thought we'd seen an improvement but actually realised it was because we'd removed the plenum cover during the process of locating the switch. With the plenum chamber cover back on we see no improvement.
We ordered a new air pressure switch just to be sure it wasn't that as Ravenheat tech support still suggested that it was most likely the cause of our fault and suggested we swap it out as it's a common fault.
We fitted the new switch but if anything the issue is now worse with the boiler failing to fire up entirely. We now cannot get it to fire up even after a significant period of time but the pilot light is still lit.
If the plenum chamber cover is removed the boiler will fire up immediately 100% of the time but as soon as it is screwed back on the problem starts again.
We obviously don't want to tinker with anything that could be a danger but if we could get a clearer idea of what the fault could be we can hopefully find a simple solution, if not we'll be forced to call out an engineer probably at great cost
Any advice much appreciated, thanks !
