Hi, I hope someone can help.
I have a Ideal Classic boiler (not combi and not the de-lux with the glass front) in my house which has worked fine for the 4 years i've been in the house. Up until about 4 weeks ago that is when it stopped working. About 2 weeks before it stopped it was making some strange noises (sounded like metal rubbing against itself) but i didn't think it too out of the ordinary as our pipes make some noise on occasion anyway, then it stopped working.. I got a Plumber out who replaced the Fan at a cost of £280 and it worked great for about 2 - 3 days then it stopped again.
This is where it gets strange!!
The boiler is now doing the same as when the fan went i.e, there is power to the boiler but it is not trying to fire, the pump is running constantly and working fine. If i wobble the boiler very slightly it clicks and fires and works as it should for about 5-10 mins then goes back to its original state of no fire in the boiler at all but the pump and everything else still pumping. If I go back and wobble it slightly again it will fire and go through this cycle again. (it also fires ok if i turn all the power to the boiler off and go through the 'light the boiler cycle' then goes out after 5-10 mins as mentioned before)
After i have got it going like this a few times and it has gone out it will sometimes re-light itself and work as it should for a while and warm the house and hot water up for a few hours (in the evening for example) but then the house will be cold again in the morning as it has stopped firing itself but the pump is still running
I got the plumber out who changed the fan and he said i need to replece the boiler and it will cost £1800. This seems like a ok price to change the boiler but as my house is up for sale i dont really want to spend this kind of money if i can help it, especially as i just spent £280 on it.
I had a brief conversation with someone corgi registered and he said it could be the Stat! does he mean a thermostat in the boiler?
Any ideas would be greatly appreciated.
Thanks in advance
Thanks in advance
