- Joined
- 19 Jan 2022
- Messages
- 1
- Reaction score
- 0
- Country
Hi there
Following the replacement of a PCB in our Potterton Suprima 40L we're having an issue whereby the output is not hot enough (even though the boiler is set to max).
Is this something that could be caused by the PCB replacement? We've checked the output pipe above the boiler and it's only 54 degrees, which seems to be the temperature if the boiler thermostat is set to 1, where I understand it should be closer to 70 according to the manual when set to Maximum.
