Hi
I have a Keston c36 (yes I know....) and have a number of people baffled on a problem.
We had the problem originally of the CH only kicking in when the HW was demanded. The HW usually works, but the CH is sporadic. It does sometimes work on the timer in the mornings 30% of times, but rarely in the evening!!
So we have, tested the diaphragm (holding pressure fine), drained system twice and applied centinel sludge remover, replaced the prv.
The symptoms now are:
Boilers starts up, pipe gets hot, display reads that temp is getting to above required setting, boiler stops, heat in pipe reduces, first radiator gets warm at best,others remain cold. Flow pipe remains cold.
The temp reading always seems to think its up to temperature and so switches off. (i'm presuming here that this display is showing the system temp, ) So it seems to me its overheating next to the boiler and unable to get the heat away, but I'm far from understanding it. Turning the HW on seems to help this, but not always.
Any ideas? My repair man has drawn a blank!
Thanks!
Thanks!
