- Joined
- 5 Sep 2021
- Messages
- 7
- Reaction score
- 0
- Country
Hi, wonder if anyone can help with the following issue.
I have a Worcester Bosch CDI 30 Greenstar boiler with a DAB 40-70/130 pump, 2 times 2 port valves one ch, one dhw. When the room stat reaches temperature the boiler temperature increases rapidly and can display U9 value which I believe is 109 degrees c. The boiler doesn’t lockout and the temp gradually comes down. I’ve noticed that the pump stops at the same time as the room stat reaches temp, not sure if it should run on? There is a bypass valve fitted a USV 16/22 which is set to zero which I think is fully open which doesnt seem right? Any advice gratefully received. Thanks.
