boiler playing up after rad removal
6 Feb 2009
Aberdeen
hi all,
so i drained the central heating system to remove a rad and valves,
no the boiler will not work properly,
the boil swithes on and heats up to 75 degrees with in a few seconds then turns off takes about 30sec to cool to 35 degrees then re fires back up to 75 degrees and continues this cycle
the pump is constantly running in this cycle
do you think there is a air lock in the boiler?
cheers for any help
