Hi, in our new fat the boiler is currently in the 3rd bedroom, and we'd like to change this.
There are two main options that I see for positioning the boiler.
The first is in a large store room at the end of the hallway, this room however has no external wall, so we would have to run the flue through to one. There are two options I see for this, the first is to run it horizontally along the ceiling of the 3rd bedroom, and then box it in. The second is slightly harder to describe. Basically, there is a peculiar cavity in the wall in the store room that I think runs up to the roof. It can kind of be pictured as a really small chimney. It doesn't seem to extend below our flat (on the second floor) and it looks as though it runs up past the attic flat above. Do you think it would be feasible/permissible to run the flue up through this cavity?
The final option would be to locate the boiler in the kitchen. The most ideal position here would be in a built in cupboard between the chimney breast and an internal wall - would I then be able to run the flue up the chimney breast? Alternatively, I could locate it on the wall the other side of the chimney, and run the flue out through the wall; however, the alcove is not as deep this side, and so the boiler would stand out further than the chimney breast.
What do you think my best option would be?
