I'm hoping someone could help. We recently purchased a 4b detached house which we pretty much completely renovated, including changing all the radiators, most of which are now collumn radiators, and adding additional ones. We've used the existing boiler which is a Greenstar 18i System boiler (18kw) with a large tank.
We are having issues, (even when the flow temp is to 75-80 degrees), the radiators never seem to get that hot, and in some instances some radiators dont heat atall. With the cold weather, its almost like the heating system struggles to get the house up to >17degrees, despite being on for a considerable amount of continual time >4h. The house is quite long, so there is a fair amount of distance for the water to travel - if that makes any difference?
We've tried balancing them, and checked enough water/pressure in the system
Most of the pipework along with the radiators are new, and the system has been flushed, and checked for air in the system.
We have 18 radiators which equates to (kw ive used an online calculator)
Most of the videos i have seen online have said for an average radiator you want to be looking at 1.5kw per radiator.
My question is, is the boiler underpowered for the radiators/setup we have? I didnt want to look at replacing the boiler, if this isnt the likely culprit
Appreciate any advice - Thanks
| TOTAL BTU | 62889 |
| KW | 18.43 |
