Boiler pressure creeping up
9 Jun 2014
Yorkshire
I had a hidden leak on my system beginning of this year. So added leak sealer.
Then a rad started leaking recently from its main body. So I binned this rad and replaced with a new one. I assume this was where the hidden leak was all along.
I now want to clean my system so two weeks ago I added x400 and have been running the heating a few times a week. I am planning on leaving it in for another week to try get any rubbish out.
Have emptied the pro 2 mag clean and it has a little crud but not loads.
But my pressure is now going up. It was running at 2.9 the other day while on. So I drained 1/3 bucket out and it went down to 1.8 bar (not on).
today it is up at 2 bar (not on).
Any idea what is happening?
Has the leak sealer gunked up the boiler?
only water will increase the pressure inside the closed system so if its going up then water is getting in. Pressure and flow are not the same so even a small amount of water can increase the pressure
Yes serviced and a new EV done this jan as we weren’t sure if the leak was this. So I decided to put a new one in to cross it off list of possibilities.
Ok I don’t think water is getting in. Will see how I get on after the clean out is finished.
