The following may be unrelated, but I'd like to explain what's happened over the last couple of days and where I am at the moment.
I've still been losing pressure. I top up the boiler to ~1.2 bar last thing at night and by the morning it's dropped to zero.
I went around the house again, checking for leaks. Only this time I took my bleed key and checked for air. All of the radiators were hot to touch, but I checked them anyway.
Downstairs was fine. Upstairs was a different story.
I have three radiators (2 of the bedrooms and the bathroom), each of them had significant amounts of air in them (although none of them were particularly cold at the top). I bled them and refilled the system to ~1 bar.
The pressure was still dropping over time.
I bled the radiators a little more. Topped up. Still drops in pressure.
Now there was no air left to remove.
It was about this time that we lost pressure in the cold water in the kitchen. The supply for the kitchen branches off at a pushfit Tee just after the main stop-cock. It's a single JG barrier pipe which goes from under the boiler (in kitchen), under the floor and re-emerges on the other side of the kitchen. This pipe has Tee's for dishwasher, sink, washing machine and finally terminates with the outside tap.
The sink tap hot (different supply pipe, obviously) was fine. The sink tap cold was slow. The outside tap cold was slow. The WM wouldn't turn on (error message: no water, check pressure/connections). The DW worked, but seemed slow to fill (although I'm not 100% on this).
The other taps in the house were all fine.
So, I had a blockage somewhere in the pipe supplying just the kitchen.
I was at work, so asked my dad to pop over and troubleshoot.
He disconnected a few pipes. Swapped over a few. And was coming close to the conclusion that yes, there was a blockage reducing the flow somewhere in the pipe from the Tee just above the stop-cock and either at, or just after, the appliacance Tee for the DW.
Before proceeding to the next step of trying to flush the offending pipe, he (for some reason) decided to reconnect all the pipes and it was at this stage he tried the tap again and it was fine! The flow was back to normal at sink tap and outside tap.
It was late, so he left it as-is for me to continue today.
Anyway, I texted him just before he left my house (did I mention I was at work all day yesterday?) to ask him what the pressure was like on the boiler. He replied, it was a zero. He topped it up, but to 2 bar. (He admits this was too high.)
I got home last night and decided to drain the system a little. I thought I'd kill two birds with one stone and emptied the TF1 filter. The first flush was black. Full of small black bits. The subsequent 3 or 4 flushes got clearer, until it was a pale beige colour, with just a few black bits in. The pressure was now ~1.4 bar.
I left it at that, fully expecting to find the boiler back at zero bar this morning.
So, imagine my surprise when I checked the boiler at 7am to find it was at >3.2 bar!
I haven't checked the PRV yet, but I expect to find it dripping.
I'm sorry if I've gone on a bit. And congratulations if you've got this far. I'm totally confused. It's gone from one extreme to the other.
