Firstly, I know there are loads of posts about similar problems, but none fit my boiler's symptoms exactly...
I have a Ferroli Optima Combi Boiler, in which the pressure drops. For example, when the central heating is on, the pressure will be about 1.5 bar say (it sometimes rises slightly when the heating is on). When the heating is then turned off, the pressure drops down to 0. Also, if the hot water is turned on for any period of time whilst the heating is also on, the pressure will drop down to zero.
I have checked the overflow pipe that runs to the outside of the building, and there is a constant drip when the heating is on. From other posts, I'm assuming there is a problem with the Pressure Release Valve but I don't know how to confirm this.
I've already been stung by an Engineer who said it was probably the Expansion Vessel, but that it probably just needed re-pressurised. He duly did this, and needless to say I was back to square one after a day. When I called him back, he suggested the Expansion Vessel may need replaced. Does it sound like a problem with the Expansion Vessel, or with the PRV?
Before I call out an another Engineer, I'd appreciate if anyone could offer advice on the likely cause.
