Hi
Problem I'm having at the moment is that the boiler pressure only returns to 1.5 bar when cool. I released some pressure in the system by opening the bleed valve on a rad so it went back down to 1.3 bar but still now only returns to 1.5 bar after the heating has been on.
Before all this happened I recently repressurised the Expansion Vessel (previous post), doing it the proper way, draing the water out of the system and pumping the water out of the EV, repressurising it to the correct value just to realise that it was the valve that was leaking causing my initial problem, so I replaced the valve.
Everything was fine for a week and the pressures were constantly correct but then to add inhibitor I isolated the bathroom rad, bled the pressure and chucked in a new dose of inhibitor, opened the rad valves again and repressurised the boiler a little, back to 1.3 bar, only since this is it not reurning to 1.3 bar when cool.
What's going on?
What's going on?
