boiler pressure question
6 Apr 2008
Kent
i have a worcester combi 24cdi boiler - the pressure dial is at 1.5 when urned off, raising to 2 when on. The red dial is at 2. Is his correct?
Might be slightly high at 1.5 bar so look at your manual for correct figure and drain some water out of rad to lower it.
Nothing to worry about though :D
.....manual doesn't give a figure! also, what is red dial for?
Usually boiler pressure is set at 1 bar cold
The red marker is there as an indication of a possible fault,BUT many are not set at any particular pressure on installation.
Going from 1.5 bar cold to 2.0 hot sounds about right ,just as said maybe a little high at 1.5,nothing too serious though
