I'm currently helping my son renovate his first house and the house had a new boiler a few years ago and was fitted with a Condensing Boiler, Potterton Performa 24 ECO HE. The plastic Condensate discharge pipe and the 15mm copper pressure relief valve discharge pipe have been run out of the boiler cupboard and along the skirting boards through two bedrooms and out of the wall. The pipes are exposed to view and look a mess.
As I am doing some work in the ceiling avoid above the kitchen which is also below the boiler cupboard, I thought I would take the opportunity to re-run the pipes through the ceiling void and out of the kitchen wall.
The pipes will need to run through 6 joists. The boiler installation manual states that the pressure relief valve discharge pipe should be 15mm copper. It would make the job a lot easier for me if I was able to use 15mm plastic barrier pipe (Hep20, JG Speedfit) instead of the copper so that it will be easier to feed the pipe through the holes in the joists. Would there be any reason or problem in using 15mm plastic barrier piping?
The first metre or so of pipe from the boiler I could use 15mm copper and then use plastic barrier pipe for the rest of the run.
Any advice aprreciated.
Thanks.
Thanks.
