The bar pressure on our Ferroli combi boiler has been creeping up to between 3 and 4 bar when we were told that this shouldn't be above 1.5 - 2. We have had the boiler off for a while but the pressure won't drop.
The problem now is that the overflow leaks outside and there appears to be a leak inside as well as I found a small pool of water below the boiler this morning.
When the pressure has dropped in the past, the boiler is fine. Is there anyway to reduce the pressure in the system?
Many thanks
Many thanks
