boiler presure
check the valves sum times weep round the gland packing on them is the blow off not dripping? you can get sum leak sealer can solve the problem altho i personaly dont like to use the stuff
Next time you re-pressursze it, watch the gauge to see if in fact the pressure goes as high as 3 bar when it has warmed up. This would lead it to lose pressure when it triggers the PRV.
