yes I know my Saunier Duval 623 combi boiler is well past its best before date and yes i know they are prone to leaking like a sieve once they reach a certain age... However @ 3.5K for British Gas to replace the unit, I'm going to have to make do again this winter!
For 6months it had leaked water and for the last 4months we have had heating (if we wanted) but no hot water.
It was leaking from the water diaphragm valve, (now called a Water Valve part #05239800). I know this as the extremely helpful SD helpline took a look at the pictures I sent them, so I could purchase the correct part (which I did).
I've just replaced the Water Valve (thanks Kev) but although I dont have a leak now, I still dont have hot water
When I open a hot tap the boiler clicks like its going to fire up, but never does the full rumble & flame thing it does, say when you put the heating on.
Even with the heating on and then opening a hot tap, I initially get hot water, but only for a short period and this seems to quash the ferocity of the flames through the pilot window.
The moment you turn the hot tap off the boiler clicks and fires up with its usual rumble and heating continues.
reading through the Fault Finding Flow Diagrams, the next thing it suggests is the sealing washers on the reversing valve. Now as this is a multi part breakdown, should I even attempt to try the next part it suggests?
What are YOUR thoughts on what might be going on in my boiler based on the description (and yes I know replacing the entire boiler would be an ideal solution! )
TIA
TIA
