Boiler problem, Vokera
13 Dec 2013
Belfast
Hey guys, I came in from work today to find my boiler has stopped working. The boiler is Vokera, hydra 26.
When I turn on my boiler everything starts up as normal, it starts purging then goes to ignition but for some reason it starts to switch between purge and ignition, it does this about 3 or 4 times then moves to fan operation. After all this happens I then get the error code, E 02 - Check gas is on, reset appliance.
The gas is working fine on the cooker and I've reset the appliance but I keep getting the same error code, if anyone knows anything about this, some advice would be greatly appreciated.
Any advice could potentially endanger you, your family and neighbors, we can't tell you anything that you can action.
You have to call an RGI Im afraid and a properly experienced one or call Vokera themselves, your boiler might just need an adjustment or it may need a component replaced but either way a flue gas analyser MUST be used to do this
