Hi, is there anyone that can help me with my boiler problem please?
I have a Worcester Green Star 38 CDI classic boiler with hot water issues. When I turn on the shower the water fluctuates between hot and cold. The temperature goes up to 110 and then it cuts out - there are no error codes. The kitchen sink tap gets to 88, but it never cuts out. It's not the shower thermostat, as I've taken the thermostat out of the shower and ran the hot water but it still over heats. The heat exchanger and divertervalve are new; also a new flow sensor. It's not the pump, as the heating is fine.
As an after thought, I reduced the water pressure at the stopcock to nearly off - the temperature stays at 65 on number 4 dial.
Thank you for your time and I look forward to reading your answers.
