Hello,
I am getting a boiler fitted and got some questions.
1. The condense connection is a bit difficult due to the position of the boiler, the only option seems to be a condense pump. I will run most of the condense inside the house, will this all have to be in 21.5mm overflow until I reach the outside which I will go 32/40mm, or does some of the pipe run inside have to be a larger diameter, the run will be over 3M. the pumping height is about 1.8M.
2. Does the Vailent Ecotec 28 Pro come with a built in filling loop or am I best fitting one externernally to the flow?
Many Thanks.
Many Thanks.
