I need to have a new boiler installed and have been given quotes for different brands and different 'opinions':
Worcester Bosch 24 kw
Worcester Bosch 28 kw
Valiant 28 kw
Potterton 24 kw
Two of the plumbers have commented that the pipeworks of the house are small and needs to be replaced with 22mm diameter ones.
Two other plumbers haven't mentioned the pipeworks, and haven't suggested a thermostat to be installed, which we do not have at present (the above two plumbers have suggested).
One of the plumber that suggested pipework has said that he will install the boiler first, and then see whether it will work and pass the tests. If not, pipework will need to be carried.
I have also been given different time frames on the completion of the work. Ranging from 1 day to 3 days.
I'm getting confused, and don't know which boiler & plumber to go with. Please help with any advice/info.
Thanks very much.
Valiant 28 kw
Potterton 24 kw
Thanks very much.
