Boiler replacement
21 Mar 2007
Birmingham
Hi all,
I have an older Worcester-Bosch Junior 28i boiler and its becoming problematic (5 breakdowns in 5 weeks is starting to test my zen like patience). I know that there is a new version, the Greenstar 28i Junior and I'm thinking about getting the old one replaced with the newer version. Both boilers are mounted on a back frame that has the incoming and outgoing pipework manifold attached. I believe the overall dimensions of the boiler are the same and installation instructions look similar.
My question is does anyone know if the positioning and order of the pipe work means that this replacement would be a relatively simple job for a qualified installer or if there is something I should be aware of or look out for.
Many thanks in advance.
